IC-706MKIIG or FT-897D
Old Feb 24, 2009 | 08:39 PM
RedDavid's Avatar
Originally Posted by kirschie
Hi Petrus
i have a IC 7000 with a AT-130 ATU in my rubicon 2008 and i a engin noise on hf have you got some advice for me i have earthed every thing i can
i have have determand that the it is the coil pack
73's ZS1DA
David
kirschie, do you take the 7000 out of the Jeep to use as a Base station as well? Curious to see an install like this. I'd like to be able to take the radio out and use in in my truck as well as the house on occasion. My 208H isn't going to cut it once I get my General Ticket.
dave
Old Mar 1, 2009 | 06:53 PM
TXEMT's Avatar
Well after all was said and done, I ordered the Ft-897D with the MH-59A8J microphone. I am still researching on the antenna. I can't figure out if I want the ATAS-120 with a duplexer or get one antenna for 2m/70cm and one for HF plus mounts...
Old Mar 2, 2009 | 10:26 AM
N2MWL's Avatar
Congrtas on your new rig purchase, hard to get hurt with either choice....
73
Mike....N2MWL
Old Mar 8, 2009 | 03:12 PM
AK4Dave's Avatar
Originally Posted by va3qrp
http://gallery.iahu.ca/v/Misc/Wrangler09/
thats my setup ... now if only I can figure out why when i key up i lose rpm and get the esp/bas light kicks on (only happens at 100W, and on certain bands like 20m but not 80m)
What a drag....that has to be frustrating. I don't doubt it that it only happens at 100w. More rf out will inevitably cause more problems everytime. It could be that the amount of wiring in the jeep itself is closer to resonance at 20m which may cause it to resonate into the computer. How is your swr on 20? Is the computer picking up stray rf at the higher ouput level? You might try installing ferrites on the computer wiring. And/or try moving your grounds to different locations. Maybe even a ground strap around the compter sort of like a shield may help. I know some hams have gone as far as to build a grounded metal box around componants to stop the interference.
Good Luck....
