Installed my CB today-YAY!!
I got myself the Midland 75-822, so really all I needed to do was install an antenna. For me, that was the hard part because I didn't know where I wanted to mount it. I decided on the tailgate behind the tire. I ended getting an L bracket mount from NAPA and used an existing bolt for my tire mount to put it on. I had to bore it out to 5/16 first. Then I feed my ground wire and cable through the vent and to the other side of the tail gate.
I attached the ground to an existing ground bolt that was put in for my rear PIAA lights and then ran the cable under the tail gate panel to feed it under the carpet all the way to the front. Then I just had to connect the CB to the cable and plug it into the power outlet.
After I got it all wired, I connected my 3' antenna and I am all set. The down side is I can't keep my antenna on because of my garage. So, I think I might get the quick disconnect now.
i like how the CB operates. Do you know of any other ways to ground it since i dont have rear offroad lights? Ive seen some people scratch there paint on there jeeps and ground to that, but that just looks like shit lol. Im guessing you could ground it to any bolt back there? also you can pretty much mount the antenna anywhere right?
im not too good with electrical work even something as basic as this lol all help is appreciated thanks
With my cable, i ran it behind the subwoofer and all the way up under the carpet. i haven't been able to figure out where i want to put the CB yet. i'm undecided on how and where to put it.
by looking at your install pics.....the ground wire is connected to your mount bolt and then to a screw on the inside of your tailgate....but NOT to the jeep's tub or frame? I think you need to run it all the way into cab and ground it there. It loses ground from the hinges.
here's my set up, before finally putting the wires and things back in order but gives you an idea of what i'm talking about (GREEN WIRE is ground- ran from the mount bolt, through the tailgate, then out to the cab following the stock wiring):
eyelet connector for ground wire shown in this pic:
and YES i had to grind paint on the mount and the cab (using the bolt for the cargo tie down) to get ground continuity
Gutless, Where did you get the button mount for the back of the handset. My midland came with just a belt clip but I've been wanting to swap it out. Guess I haven't looked into it much, is it just a generic part to swap in the normal CB style hanger or what?
i found it on some CB parts website. Then I just got some JB weld and stuck it on. hope this helps.
