Just received my Cobra 75 WX ST
Old Mar 21, 2012 | 05:51 PM
jim hensley's Avatar
Default Just received my Cobra 75 WX ST
Going to do the install this weekend. Love all of the great install threads and will be following these closely. I choose the Teraflex left side tail light mount. Any advice on this antennae mount and grounding?
Old Mar 21, 2012 | 10:07 PM
MrFish's Avatar
Does the TF taillight mount work with the 2011-2012 taillights? I thought it was only for prior models.
Old Mar 22, 2012 | 03:49 AM
I think you are right after some direction search it only showed installation on the Yj an tj etc. got to make a call today. Should I stay with Teraflex or go a different direction?
Old Mar 22, 2012 | 06:03 AM
RUBINOT's Avatar
I think Teraflex makes a spare tire carrier mount for the CB Antenna. Easy bolt on.
Old Mar 22, 2012 | 09:23 AM
MrFish's Avatar
The Ultramount from Cool Tech LLC will give you roughly the same look/location. I like mine.
Old Mar 22, 2012 | 09:26 AM
animated_robot's Avatar
x2... I use the TF spare tire carrier mount for my CB and everything works great. I didn't have to run any extra ground leads, and my readings are within specs or better.
Old Mar 22, 2012 | 12:24 PM
Looked at the Ultramount and then bought the Teraflex mount. What a difference in price for something that looks pretty simple. Here's the question. Do you really need to take the mount area's down to bare metal to get a good ground? If this is the case what and where and how do you keep this from corroding in the future?
Old Mar 22, 2012 | 12:36 PM
evoviii2jk's Avatar
I have the TF mount for the spare tire. I just ground the finish off only right where the antenna mount hits it. Works great. I also have the firestik quick disconnect for when I'm not using the CB. I store the antenna in the roll bar cover when not being used
Old Mar 22, 2012 | 02:15 PM
That's a great idea on the antennae storage! I've got the quick disconnect as well. Thanks for the info
