My Cobra 75 CB and antenna install
Old Jan 1, 2012 | 09:06 PM
  #441
psouza's Avatar
Originally Posted by Heretic
I am using a 3ft firefly antenna.
On the check list for tomorrow. Ground the remote unit. Remove make shift bonding wire. Check SWR with gate closed and open. Cuss. Research bonding straps some more. Researching base loaded wire whip antennas. Care to recommend any?
You are the beacon of light.
V/R
Jason
Blink, blink! Can't recommend a brand of antenna, but mine is a Radio Shack made by Wilson. If a wire whip is not readily available, a longer (if possible for you) fiberglass tunable whip will also work (electrically) well for you. Longer is always better and can bring the VSWR down a lot just by length alone. Recommend bonding straps for last . It is an ugly job, done right.
Old Jan 2, 2012 | 06:09 AM
  #442
Heretic's Avatar
Well off to start the days adventure. Thank you for the help and hope this helps others as well.
Old Jan 2, 2012 | 06:17 AM
  #443
JKRazz's Avatar
Originally Posted by HG07JKRubi
I couldn't really find a spot I liked in the JK to install my 20 year old Cobra 20 CB so I picked up the popular Cobra 75 all in one unit and thought I'd share some pics of the install...
First the antenna, a 36" Firestick mounted to the spare tire carrier (purchased the mount from a local CB shop that sells through Quadratec). The antenna cable is routed through the same rubber grommet used by the brake light wires.
The CB box is installed under the glove box on the metal bracket and quick disconnect on the panel beneath the glove box. (This is wired directly to the battery)
Cooltech VersaMount with cb mic bracket riveted in ...
Finally, the mic mounted on the CoolTech VersaMount:
That's it...it sounds great and the antenna tuned real well...off to the trails !!!
That is awesome. I love the clean install look!! I am starting to hate this forum....I keep seeing things that go onto my "To Do list"...LOL
Awesome Job!!!
Old Jan 7, 2012 | 02:16 PM
  #444
evancise's Avatar
Default Install complete
I finished my install today. Now all that's left is to tune it. Same basic install up front as everyone else. Here are a few pics of my antenna mount. And yes, the mount is grounded to the subwoofer bolt, it just wasn't installed when I took the pictures.
ID:	260754 Click image for larger version
ID:	260757 Click image for larger version
I didn't use the metal plate under the dash for the pass-through - just the rubber grommet. Will this come back to bite me? Should I go drill the holes and mount it?
This is the "metal plate" I'm talking about:
Old Jan 16, 2012 | 01:40 PM
  #445
monkers's Avatar
This is a great thread! I like the radio, but am concerned about having the mic mount down in that panel, worried about the dog getting into it, could it be put in the center panel, down low. (I have a Rubicon) or somewhere there abouts, Ive seen some of the sound bar mounts also but they mentioned its a PITA to "tune".....do you have to tune the radio often or just when you install it? I also like the small roll bar mounted hidden speakers, does anyone know the manufacturer of them or where to get them? Thanks
Old Jan 17, 2012 | 09:08 PM
  #446
soldiersJK's Avatar
Finished the install, attached junction directly to the battery and secured the connector under center section of dash. Mounted mike using cooltech versamount, mounted firestick to tailgate mount and coax cable run along tube to main box and ground wire to inside acorn nut to rear speaker, all wires hidden to clean up look.
ID:	266301   Click image for larger version
ID:	266302   Click image for larger version
Old Feb 14, 2012 | 07:53 PM
  #447
JK-jeepit's Avatar
bumping this to the front....
hope it helps out some others
Old Feb 18, 2012 | 07:08 AM
  #448
TengoHotel's Avatar
Very nice install! This is gonna be a big help to me this weekend as I do mine.
Old Feb 19, 2012 | 05:44 PM
  #449
SayreJK07's Avatar
Does the base unit have to be screwed down, or can it just be zip tied in place?
Old Feb 19, 2012 | 06:18 PM
  #450
JK-Rubi's Avatar
Not sure what others did, but one side I zip-tied and the other I screwed down. Been working great that way for 3 years now.
