My Cobra 75 CB and antenna install
Old Feb 19, 2012 | 06:27 PM
  #451
skully's Avatar
Originally Posted by SayreJK07
Does the base unit have to be screwed down, or can it just be zip tied in place?
I just zip tied mine. Works great!
Old Feb 20, 2012 | 02:51 AM
  #452
tcdawg's Avatar
I zip tied mine in my TJ and now in my JK. No problems at all.
Old Feb 20, 2012 | 06:35 AM
  #453
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
IMHO, as long as you have the ground wire on the base grounded, you should be ok.
Old Feb 26, 2012 | 08:56 AM
  #454
jw-ewing's Avatar
Originally Posted by TORN
I would like one of the mounts for rear tire but couldnt find it on quadratec site or catalog, any info on how to get one would be appreciated.
I found it at this website: http://www.walcottcb.com/jkcbm-jeep-....html?cPath=28
Hope this helps
jw-ewing
Old Feb 26, 2012 | 09:00 AM
  #455
Deere_Jeep's Avatar
Zip Tied mine.
Old Mar 1, 2012 | 07:01 PM
  #456
GPorts's Avatar
When getting an external speaker, does it connect to the mic or to the original box that the mixis hooked up to?
Old Mar 1, 2012 | 07:09 PM
  #457
JK-jeepit's Avatar
it connects to the box, there is a jack next to the coax connector.
Old Mar 1, 2012 | 07:11 PM
  #458
Sapper12b's Avatar
Originally Posted by soldiersJK
Attachment 266304
Finished the install, attached junction directly to the battery and secured the connector under center section of dash. Mounted mike using cooltech versamount, mounted firestick to tailgate mount and coax cable run along tube to main box and ground wire to inside acorn nut to rear speaker, all wires hidden to clean up look.
Can you show a pic where you mounted the junction box ?
Old Mar 2, 2012 | 06:14 PM
  #459
SCJK10's Avatar
Zip tied mine under the passenger seat, works fine.
Old Mar 2, 2012 | 06:20 PM
  #460
SCJK10's Avatar
I would also add that the tailgate ant mounts don't work very well, too much reflection.
