New to CB radios
Old Mar 12, 2016 | 12:15 PM
07 Rescue Green's Avatar
Veteran: Navy
Originally Posted by CRAWL TV
We just installed a Cobra 75 WX ST and it works great. The handheld system, similar to the Midland, eliminates the need to mount a large box somewhere. We put an install video together, too. Check it out!
https://youtu.be/c3CgK3uTWkI
I watch your video plus a couple of others, gotta say your's looks the cleanest. Where did you get the wiring harness for your power?
Old Mar 12, 2016 | 12:26 PM
CRAWL TV's Avatar
Thanks! We really appreciate that. We're not expert video makers by any means, but we tried to be as thorough as possible to help the viewers. Here's the link to our accessory tap:
http://www.quadratec.com/products/96080_9801.htm
Old Mar 12, 2016 | 06:28 PM
Baja JKU OllllllO's Avatar
Vet Army
We just installed a Cobra 75 WX ST and it works great. The handheld system, similar to the Midland, eliminates the need to mount a large box somewhere. We put an install video together, too. Check it out! https://youtu.be/c3CgK3uTWkI
Nice install! Where did you get that CB mount that mounts by the passenger grab handle?
Old Mar 13, 2016 | 08:06 AM
CRAWL TV's Avatar
Thank you! We purchased it through Quadratec. It's made by CFE Products. Here's the link:
http://www.quadratec.com/products/96080_213.htm
Old Mar 13, 2016 | 11:53 AM
theandyman's Avatar
What is the advantage of taking apart the whole dash to tie into the power as opposed to running direct from battery.
Seems like from battery requires much less tearing apart of dash
Old Mar 13, 2016 | 12:12 PM
CRAWL TV's Avatar
Originally Posted by theandyman
What is the advantage of taking apart the whole dash to tie into the power as opposed to running direct from battery. Seems like from battery requires much less tearing apart of dash
It's a much cleaner job to tie in to an accessory power supply. Not to mention, we don't have any loose wires running directly from the battery. When we shut the jeep off, the CB system will shut off as well, rather than becoming a parasitic drain if we forget about it and leave it on. The dash is VERY easy to remove in the 2011-Current JK. It requires a single flat-head screwdriver and a 7mm socket. Without pausing to record a video, we can pull the whole thing out in just around 5 minutes.
