NON license plate CB antenna mount?
x2 on Arizona Rock Road....
A lot of discussion in some of the older threads if you search.... e.g...
https://www.jk-forum.com/forums/jk-cb-ham-radios-128/where-your-cb-mounted-9582/
https://www.jk-forum.com/forums/jk-cb-ham-radios-128/cb-antenna-mount-jk-installed-1997/
I used the standard trucker 's L shape mirror mount. I took the spare off, remove the 3 eye cover and the other 2 screws that held on the cover. Drop the wires down. Hold and clamp the l bracket to the back, level and mark holes for supplied bolts. Now install the L bracket on back side and v shaped flat bracket with wires in V on the inside. Put every thing back together and install 3ft antenna and run coax cable.
The 3 ft antenna is about 1 inch higher than soft top and will give a fair distance.
I'll try to post finished pictures later today.
Lets see those Pics
