quick question about firestik quick disconnect
Old Dec 30, 2013 | 05:57 PM
MF11283's Avatar
Default quick question about firestik quick disconnect
hey I have a firestik 2 and a firefly antenna that I just got my firestik quick disconnect for. I tuned the firestik2 and got the swr by my meter down in the 1.1-1.2 range across pretty much all the channels, so IM asking ahead of time so I know about what to expect, what will this quick disconnect do to my swr reading? should I be looking for it to make my antenna electrically long? or will it just make the reading go up across all channels? I have searched the net and the forum and havent found (not saying its not out there) the exact answer to this question however I have found that you can make an antenna longer by adding a spring so IM going to guess its the same?
Thank you
Michael
Old Dec 31, 2013 | 02:49 AM
OH9JK's Avatar
JK-Forum Ambassador
yes, the quick disconnect will make your antenna electrically longer. You should perform another SWR reading once you have it installed and adjust as required.
