Range Questions Help!
Old Jan 20, 2015 | 05:42 AM
smittycm's Avatar
Veteran: Marine Corp
I'm thinking that your antenna placement will primarily effect the range you get out of your transmissions and not how well you're able to tune your cb. Double check the placement of that plastic washer on your antenna stud and make absolutely sure that the lower part of the stud isn't touching the inside of the mount. That was my problem initially and was causing horrible SWR readings.
There are some awesome guides online to walk you through troubleshooting using continuity tests in various spots to find the short. If you're getting bad SWR readings, then 90% of the time it seems to be a bad ground or a short somewhere. I used a $5 multimeter from Harbor Freight to find my short and it literally took about 10 minutes.
Also, I noticed a huge difference when I went with quality components. Not sure what coaxial wire you're using, or what antenna, but I started off using the no-name stuff off the shelf of my local Fry's. I switched to a nice Wilson Flex 4' and Wilson coax and the difference was very noticeable.
The good thing is that once you get it dialed in you shouldn't have to fart with it again! Good luck!
Old Jan 20, 2015 | 01:24 PM
CombatDiver's Avatar
Make sure it's grounded good, that tends to help when experiencing similar problems like you have described.
Having a tuned antenna is crucial. It's likely that the antenna you bought isn't the problem since it is straight forward and those firesticks tend to be tuned already.. It's even less likely the feedline is responsible. The best way to rule them out is set them up outside of the vehicle and test them. Only changing one piece of any part of the transmitting and receiving stations to narrow it down if it is a component like the antenna that is causing this. Once the system is determined to be working properly go ahead and mount it to the vehicle.
Old Jan 20, 2015 | 04:23 PM
2climbbig's Avatar
I agree, it is a bit of a crap shoot about combinations of antenna with cb radio and length of cabling. But, I disagree a bit on reception vs broadcast. Take your antenna for your garage door/gate opener which is nothing but a piece of wire cut to a specific length. Cut a new one one inch shorter and install it. Then see what your range is. it will suck! This happened to me. My gate antenna got caught on my ladder and I ripped it from the box. I broke the wire about an inch from the box. I removed it and put the remaining wire back on the box and my range was cut by more than half. I had to get another wire and put it in. I guessed how much wire was lost and it took 3 times before I got it right. I had thrown away the remaining wire so I did not have the exact length. I don't see this being any different.
Old Jan 20, 2015 | 04:51 PM
jnabird333's Avatar
The problem with the garage door/gate analogy is both ends are broadcasting and receiving. It's tough to say what end suffered from the poor antenna and if it was due to poor reception or broadcast.
Old Jan 20, 2015 | 06:37 PM
2climbbig's Avatar
Crap... really. I did not know that my gate opener broadcasted. I just assumed it only received. I click the button on my remote and the bloody thing opens. I know you have to set the right frequency, but I did not know it was a request/response type of set up. Huh. Learning something new every day
Old Jan 20, 2015 | 06:43 PM
2climbbig's Avatar
Ok, I don't know what type of gate opener you have, but mine is purely a transmitter. I just opened it up to take a peak. There is no receiver on it.
Old Jan 31, 2015 | 04:12 AM
BrowniesJK's Avatar
Guys, just wanted to thank all of you for the help. Finally had a chance to rework my setup yesterday and tested it out last night. Couple of miles range and it sounds great. The issue was all ground related. I played with different coiling of the coax and really didn't see a difference in SWR so take that for what it's worth. Thanks again. This forum has always come through
ID:	594535   Click image for larger version
Old Feb 3, 2015 | 09:38 PM
sea bass's Avatar
Originally Posted by mattfl
Our little group of Jeeps recently decided we all needed CBs. We all purchased uniden pro520xl CBs and various size firestiks depending on our setup. I have a 3' firestik mounted to my license plate bracket with no spare tire. I've turned via a SWR on channels 1/20/40 and get the readings I should be, all 1.5 or less. My friend has a 4' firestik mounted to his rear poison spyder bumper, he only turned on channel 40 and gets under 1.5 on the SWR. Our problem is this, within 10-20 yards we are great. The farther we get away the less I can hear him. He can hear me just about perfect, even from almost a mile away, however I can hardly hear him. The other weird thing is, I can pickup much more random traffic on all the channels, even sitting right next to each other, on the same channel, i pick up more than him. Is it a problem with his setup or mine? Could it be because he's not tuned on 1/20/40 and just on 40 that he's really not all that tuned? Could the mount on his rear bumper be the issue, possibly not grounded enough? We are pulling our hairs out trying to get these things setup. Any help would be appreciated.
I don't know much - but it could be something as simple as your settings. Are you familiar with the settings in your radios? Specifically rf gain? I wasn't when I first got my 520 and was having similar issues.
Old Feb 4, 2015 | 03:40 AM
mattfl's Avatar
See BrowniesJK post right above yours, we got it all worked out
Old Feb 4, 2015 | 04:08 PM
sea bass's Avatar
Ha! I didn't catch that - glad you got it all worked out.
