Show me where and how you are mounting you CB mic!
Where is you CB mounted? When I put my Uniden 520xl in the middle lower console I put the mic holder under the radio it was perfect. Now I have my Uniden Grant imstalled above my mirror and the mic holder is on the side of the CB. I would like a retracter like goodysgot cuda I will try to post a picture.
I have the cobra 75... mounted it behind the glove compartment and ran the disconnect through the dash (comes out below the glove compartment). Saw someone's write-up a while ago and decided when I get the CB, I was going to follow it as well as I could remember it.
Anyway, the actual hand held unit (all in one thing) is still floating around. I am going to go ahead and put the mount in the same place you have it (between the vents). It did not shift around or anything when you were wheeling?
How was the room above the bracket? Does the stereo get in the way, when trying to clip it in and pull it out?
Glad you asked, be sure to put it as high as you can and still get the micout ok, I had it lower at first and I would hit it when shifting in to 3rd. Other wise it is a great location. You know it is really easy to take the vents out to see what is back there, there isn't anything there on my jeep.
I think the best place is thru glove box run it flush on bottom with inside and you only lose 2 - 2 1/2 inches and the best part is it locks with ign key i bought the tuffy over head console it was huge and seemed to much for little cb
this is clean and easy only cost is trim for car door cut at length put on ruff hole and slide cb in screw cb to back of glove box and thats it
works for me
here are some pics
works for me
