So where have you been mounting the CB's?
Old May 30, 2011 | 05:35 PM
  #91
roadking54's Avatar
Old May 31, 2011 | 07:46 PM
  #92
Sahara Lee's Avatar
I have the Cobra 75 with CoolTechLLC GateMount.
4' Firestik FireFly mounted on inverted GateMount allows me to drive under garage door opening with just a bit of flexing.
VersaMount attached using existing scews behind trim. No dash modification required.
Connector box mounted hidden below glove box. 2 small screws holding CB connection box and plug mount hole in the kick panel below glove box are all the modifications needed. Ground is landed under black screw. Power is run directly to battery through foam-filled hole where passenger dash trim meets body. No drilling required. Just push wire thru foam.
CB screen and controls are all on mic. The controls are all visable and accessible from the driver's seat without taking the mic off the VersaMount.
Old Jun 1, 2011 | 07:08 AM
  #93
Vector Offroad's Avatar
Sponsoring Manufacturer
Cobra 75wxst, main box mounted under the glove box, and I keep the mic mounted to the Vector Off-Road E-Dock. I can move it around as needed. I keep the HAM mic on the front side of the mount and the CB on the back side of the mount.
http://www.vectoroffroad.com/jke-dock-p-28.html
ID:	166709Click image for larger version
ID:	166710Click image for larger version
Old Jun 1, 2011 | 06:35 PM
  #94
xerofall's Avatar
Within reach.
Old Jun 1, 2011 | 07:15 PM
  #95
Sahara Lee's Avatar
The foam-hole power pass-through (push back passenger side dash trim) is great for routing the power wire directly to the battery thereby reducing electrical noise.
With mic disconnected and stored in the console you hardly know there's a CB at all.
Old Jun 1, 2011 | 07:19 PM
  #96
210GoldenEagle's Avatar
Originally Posted by roadking54
Where did you get the plastic piece to mount the unit in your glove box?
Old Jun 1, 2011 | 10:01 PM
  #97
jeepairforce's Avatar
I found this to be an easy install and have had no problems with it.
[IMG]
By harkev at 2011-06-01[/IMG]
[IMG]
[IMG]
Old Jun 1, 2011 | 10:09 PM
  #98
jeep_creep's Avatar
Above the mirror???
ID:	167123   Click image for larger version
ID:	167124   Click image for larger version
Old Jun 2, 2011 | 06:42 AM
  #99
scotty6336's Avatar
mine hangs between the visors as well and I love it there, easy to read channel strengh and change, acutal mike hangs from soundbar
Old Aug 15, 2011 | 07:40 PM
  #100
JK09's Avatar
Is there a remote faceplate mouting kit out there for a Yeasu 208H or Icom 7900R? I was thinking of putting the faceplate on the dash and hiding the radio in some as-yet-undetermined place. Any help would be appreciated!
If anyone has suggestion for a suitable UHF/VHF bumper mounted antenna and auto-tuner I would love to hear it! ! !
