speed calibration km/h to mph
Old Feb 2, 2008 | 05:38 AM
jeep_poser
Guest
Posts: n/a
Default speed calibration km/h to mph
If I re-calibrate my speed sensor with an aftermarket computer to adjust my dash from km/h to mph using the correct ratio, will it have a negative impact on the rest of the systems on the car.
Old Feb 2, 2008 | 11:13 AM
James76's Avatar
as long as you are using that is deisgned for your vehicle i wouldn't think any harm will come from it.
Old Feb 3, 2008 | 04:04 PM
jeep_poser
Guest
Posts: n/a
Default Accu Pro
I'm thinking of using an ACCU PRO unit. Will that screw with my car in any way. If the speed coming out of the ACCU PRO to the vehicle's systems isn't the same as the actual speed... (I have a 6SPD Manual JK)
Old Feb 3, 2008 | 05:13 PM
Sv650's Avatar
Strikes me that you might also open yourself for odometer tampering if you record miles on an odometer marked KM.
If you want an imperial readout, might the use of a GPS meet your needs?
SV
Old Feb 3, 2008 | 07:41 PM
jeep_poser
Guest
Posts: n/a
hi sv650... i might call myself cbr600rr hehee
Naw, not interest in GPS. Just want to know if the vehicle will perform poorly if the wheel speed is inaccurately read by the car's computer.
I'm also considering the Hypertech Max Energy #52001
see: http://www.4x4rockshop.com/prodimage...gy_jk_dyno.jpg
good for rear axle ratio 5.13 conversion which will give me a very clsoe approx of km/h to mph 3.21/5.13 =~ 60mph = 100km/h
+fuel economy and more hp apparently... (yeah right)
Old Feb 4, 2008 | 11:51 AM
James76's Avatar
You can get just the speedometer calibrator for like $229 its hypertech part # 752001 2003-2007 dodge hemi 5.7L Truck/SUV
I can verify that this does work on the JK
Old Feb 5, 2008 | 08:59 AM
jeep_poser
Guest
Posts: n/a
Will the Max Energy for 375 make up for the 150$ difference in fuel savings over 2 years?
