Static through the CB
Old 07-24-2017, 12:10 PM
dalejrfan88's Avatar
Default Static through the CB
This is strange to me so I am throwing it out there but hopefully not strange to someone so I may possible get a solution to the problem. I installed a CB in my 2016 JK. The antenna is mounted behind 2 bolts on the spare tire carrier. If my squelch is set low enough, when I turn on my blinker, I get static through the radio each time the blinker lights up. I also get static through one of my switches on my switch pod. I lights (blinkers & pod lights) are LED's. I thought this could be a ground issue but all lights are solidly grounded. Can anyone offer up any additional thoughts?
Thank you in advance for any help.
Old 07-24-2017, 02:52 PM
jchappies's Avatar
Run the antenna cable separate from any other wires, ground off app powder coat from the antenna base so all bolts and pl-259 adapter have a good ground to the tail gate, and ground the tail gate to main body. and run your radio ground straight to battery.
Old 10-21-2017, 05:13 AM
DRRitchie's Avatar
Default Grounding
It's s common problem and easily fixed by running a ground strap (braided woven flexible) from the antenna base or nearest metal location to the chassis. I even strapped the engine to the chassis and to the hood via the firewall to cut noise. I run Ham HF a lot (national and international) and SSB (AM) needs all the help possible to reduce noise. Good luck and happy trails!
Quick Reply: Static through the CB
