SWR Was 1.4 installed firestik now 3-4?
Old Jun 13, 2009 | 11:19 AM
wwiifirearms's Avatar
Default SWR Was 1.4 installed firestik now 3-4?
I had a Francis 4.5' Fiberglass Antenna and had good SWR around 1.4. Someone broke it off while my jeep was parked
I just went and bought a 4' firestik and installed it and my SWR is over 3 accross all channels!!! Obviously I can't use it like this without damage to the radio.
Since nothing changed in the mount, location, coax, or radio, what could cause this?
I took the mount off and ground off more powder coat to make certain I had good ground (but I don't know how to check the ground is good). No change.
Any ideas or procedures for testing potential issues?
-wwiifirerms
Old Jun 13, 2009 | 12:09 PM
Update: I moved the stud to the second hole in the tereflex mount, which I had not removed the powder coat from, and it dropped to around 2. Better, but not good yet. My guess is I have problem with my stud shorting out. With it in the other mount hole, I am guessing it isn't shorting, but now the shield isn't properly grounded.
Am I right to think the stud should allow the shield to ground to the mount, but not allow the stud itself to ground?
-wwiifirearms
Old Jun 13, 2009 | 12:36 PM
Thanks.
I expected to need to tune the Antenna, but with SWR at 3+ across all channels, I don't think tuning the length is going to help. I am wondering if the bone head broke off my antenna also cracked the insulation inside the stud when they broke the antenna off.
Since disrupting the ground to the stud improves the SWR, I must have short somewhere. I'll replace the stud first, then try to find a short in the coax ends if the stud does work.
Can anyone tell me how to test for a short in either the stud or the coax. I have a multi-meter, just not real familar with using it to check anything other than voltage.
-wwiifirearms
Old Jun 13, 2009 | 01:33 PM
Is it possible to have a short in the Radio?
Using the multi-meter (I think correctly) the outer shielding stays grounded and the antenna lead stays ungrounded (no short), until I plug it into the radio at after which I can detect some ground in the antenna wire.
Is this normal?
SWR still way over 3 with the antenna mount grounded and around 2 when the antenna mount ground is disrupted.
I am stumped, but that isn't always hard to do.
-wwiifirearms
Old Jun 13, 2009 | 02:53 PM
AK4Dave's Avatar
Hook up your antenna to the mount like you would normally. Then disconnect the coax from the radio. Put your tester on "continuity". Turn on the tester and touch the probes together to see if you hear a tone or a light lights up. Then touch one probe to the center of the coax (hot) connector and the other probe to the outside (ground) of the connector. If you hear a tone, or see a light from the tester when you touch them then you have a short.
Old Jun 13, 2009 | 03:05 PM
Thanks. I followed your proceedure.
It does not appear to have a short.
Multi-meter reads 0.930 when probes not touching, and 0.288 with probes touching each other. With one probe on each portion of the coax it still reads 0.930. I think this means no short in coax, mount, or antenna.
So what could it be?
-wwiifirearms
Old Jun 13, 2009 | 03:52 PM
medbender's Avatar
dude, just tune the antenna. some have a screw on top but most you'd just trim about 1/8'' off at a time. dont forget to put the cap back on before testing. I took about 1/2'' off mine before it was right but that will vary.
Old Jun 14, 2009 | 12:19 AM
AK4Dave's Avatar
What???........I wouldn't go tellin' somebody to start hacking off his stinger before you know it even needs to be trimmed, because there's no going back after that. How do you know that it doesn't need to be longer? Yes he could try adjusting it but if it reads over 3 all across the band I'd say there's something else going on there.
wwiifirearms......did you try adjusting the stinger at all? Are the swrs better on one end of the band? Remember this.....the lower the frequency the longer the antenna......the higher the freq. the smaller. Try extending the stinger and see what happens, if anything, at least that will tell you if the stinger "may" need to be trimmed. Put it on channel 1, check the swrs, extend the stinger and if the swrs get better at all on channel 1 then the antenna could be too long. But if you extend it all the way out and nothing changes then there indeed is something else wrong. The antenna has to be way too long or way too short (which is unlikely) for there not be any change in swr at all when you adjust it.
Oh, about the radio having a short.....unless you were transmitting when the antenna was broken off it should be fine. You may have to start looking closely at the coax and make sure there are no severe bends in it somehwere. Or, do you have access to another coax? You can try that an see if anything changes. Also make sure your ground is still good.
Old Jun 14, 2009 | 08:39 AM
Originally Posted by Ridin' Dirty
unhook your coax from your radio and take your multitester and touch one lead to a chassis ground and the other lead to the outside of your coax connector this will tell you if your antenna mount is grounded....
Thanks. Did this test and it is grounded.
Someone mentioned a stinger, what is this?
Right now:
SWR on channel 1 is 2.5
SWR on channel 40 is 3.9
-wwiifirearms
Old Jun 14, 2009 | 08:54 AM
if you keep moving things around you'll be scratching your head forever. This is what you do:
put the cb on channel 1 and take a swr reading and write it down, then put the cb on channel 40 and do the same thing. This will definitely tell you if the antenna has to be longer or shorter. If the swr's are better on channel 40 then the antenna has to be lengthened, and if the swr's are better on channel 1 it has to be shortened. Another thing you can check is your little jumper wire for the swr meter, unscrew it from everything and check it with your ohmmeter. Check the center conductor and the shield making sure they are both making contact to the connectors and also make sure they are not shorted to each other. Dave is right don't go hacking the antenna up till you know for sure it needs to be hacked.
Since channel 1 was 2.5 and channel 40 was 3.9, I took off about 3/8" (half of one coil) and now they are 2.9 on channel 1 and 3.3 on channel 40.
Since Channel 1 is getting worse I don't want to keep cutting.
Thanks for the continued help. The nearest CB shop I know of is at least a 90 minute drive each way, so I am try to avoid making a trip. Plus I don't think they are open on the weekend.
-wwiifirearms
