SWR Off the Carts
SWR Off the Charts
Hey Guys,
I'm not the most knowledgable when it comes to CBs, but I have tried to troubleshoot my problems using existing forum threads without any luck.
I have the Uniden 510 kit from right channel radios with the Teraflex mount. I removed some of the material on the mount and grounded it to my frame. I have checked continuity to ensure that it is in fact grounded. I also made sure that the COAX was routed without any kinks, pinches, or loops in the cable. I routed it along the passenger side underneath the carpet and then under the front passenger seat.
When testing the SWR, I follow the directions included, and when I switch the meter to "REF", the meter pings all the way to the right. I have no idea what could be causing this. Any advice on how to fix this would be greatly appreciated.
Yes, I am using an external meter. It is the one that came with the kit, not sure of the brand. The antenna is a 3' Firestik adjustable.
Do you own a multimeter?
If so, I would check to make sure your coax or antenna does not have a short in it.
Typically SWR is high with that mount but not pegging the meter.
Checking coax with a multi meter:
1. Set the multimeter to either the resistance check (ohms) or diode tester (beeps when shorted).
2. Check between center pins to make sure there is no resistence.
3. Then test between the center pin and the out side metal part that screws on to the antenna. If it is good there should be no connection and infinite resistance.
[QUOTE="Stephens2r;3826487"]Hey Guys, I'm not the most knowledgable when it comes to CBs, but I have tried to troubleshoot my problems using existing forum threads without any luck. I have the Uniden 510 kit from right channel radios with the Teraflex mount. I removed some of the material on the mount and grounded it to my frame. I have checked continuity to ensure that it is in fact grounded. I also made sure that the COAX was routed without any kinks, pinches, or loops in the cable. I routed it along the passenger side underneath the carpet and then under the front passenger seat. When testing the SWR, I follow the directions included, and when I switch the meter to "REF", the meter pings all the way to the right. I have no idea what could be causing this. Any advice on how to fix this would be greatly appreciated.[/QUOTE Make sure your coax is cut in a 3ft interval. Example is a 18 ft coax is a great length, a 16 ft cable will not have good swr's no matter how much you adjust!
There is a portion of this link from the ARRL that explains is quite well. I have posted this in another thread on this forum, for a different reason so I may appear to be a "One Trick Pony". For tonight perhaps.
There is a section in the article that depicts the relationship of measured VSWR to actual power lost. Should give perspective to the worriers who obsess over the ratio numbers. Kind of a mental health aid.
http://www.arrl.org/files/file/Techn...f/q1106037.pdf
Phil
