Wipers , dashlights and signals flash
I installed my CB recently and hooked up a power wire with inline fuse directly to battery as also the ground. My antennae is a 4 ft firestick mounted on rear carrier and I SWR is at 1.4 on channel 19 and less on my usual run channel 4.
When I key the mike the wipers go off, headlights and signals flash and my dashlights blink
Is this anything to do with my keyless system is receiving false signals when I key my mike?!?
I have the same issue. Does your radio turn off too?
Try this thread, it might help you. I haven't had the chance to do any but they might work for you.
https://www.jk-forum.com/forums/jk-c...ronics-251293/
