Yaesu FT-7900R and Comit CA-2x4SR?
Old Nov 12, 2009 | 05:43 PM
w squared's Avatar
Originally Posted by Skippman
Anyone who has both a HAM AND a 1911 is ok in my book.
+1 on that.
You forgot to mention that he has a Jeep, too.
Hmmm...makes me think of something....shoot, move, communicate...I've heard that before...somewhere
The cupholder mount looks like the position is great, but I use my cupholders more often than not. I like my espresso too much to give it up if there's a reasonable alternative.
Old Nov 13, 2009 | 03:47 AM
N2MWL's Avatar
That Arizona rack is pretty interesting but I don't know if I like having that extra bar up there.
LOL..
Originally Posted by lawman07
x2 on the cup holder mount for now. I really liked the daystar too, but would rather have the option of tossing the whole thing in the console. Out of sight, out of theiving hands.
The face can be taken out of the sep kit in just seconds and locked in the center console/glove box or taken with you..
Originally Posted by w squared
+1 on that.
That is the only draw back is your giving up a cup holder, my other one is filled with spare change !!
Old Nov 13, 2009 | 11:09 AM
Skippman's Avatar
Originally Posted by N2MWL
LOL..
Hopefully that's the ONLY change you're interested in.
Old Nov 13, 2009 | 01:12 PM
eraujk's Avatar
I love my radio! Biggest complaint is I wish it could talk on AM. Im a pilot at an Aviation School and it would be nice if i could talk to my buddies while im out!
The radio it self is mounted under the passenger seat. Its attached directly to the bottom of the seat to keep it off the floor where it might get kicked or water could hit it. The display is mounted to the plastic thing in front of the stick using 2 more 90 degree brackets and then screwed into the mount that came with the radio.
The full Set up.
Took a 90 degree wood brace bracket and bent it. It had 4 holes already drilled though it. just attached the mic bracket and then screwed it into the console. It doesn't look the best on its own but it does the job and nobody notices when the mics there.
Old Apr 5, 2010 | 03:59 PM
Verdulken's Avatar
Got the same radio and this was my mounting solution.
I had the daystar upper dash board modification so that's where I installed the faceplate, the remote wire goes through the back of the dashboard and into the main unit which I located under the passenger’s seat.
Old Apr 5, 2010 | 05:36 PM
GadgetPhreak's Avatar
I did my Icom's about the same with the daystar top panel, worked great. The second remote head I attached the bracket to the panel in front of the shifter.
https://www.jk-forum.com/forums/jk-cb-ham-radios-128/two-icom-1821s-f3061-installed-125370/
What I didn't post a pic of was the remote speakers which are both mounted to the roll bar between passenger and driver - which works great and is extremely easy to hear during a mission.
So far, I'm really happy with this set up. Now working on a dual band head unit with APRS (actually working on a DPRS solution so I can stick with ICOM, they're located here in Bellevue and are amazing quality...).
Old Apr 6, 2010 | 12:34 PM
Verdulken's Avatar
Just checked your post and left a reply.
Nice area where you live, I was up in Kirkland for almost a year working for Medtronic Corp. Really nice up there
Old Apr 8, 2010 | 06:25 AM
Skippman's Avatar
There's no adapter to plug the mic directly into the radio itself on this unit right? You have to run it through the faceplate?
Old Apr 8, 2010 | 06:47 AM
Verdulken's Avatar
Right, it only connects to the faceplate.
Old Apr 8, 2010 | 10:49 AM
Vernnz's Avatar
Do you know if the FT8800 and FT8900 can be MARS modded in the same way?
kb2ljj.com/data/yaesu/ft-8800.htm
eham.net/forums/ModsAndRepairs/5733
The OP of that one did it himself. You could email and ask the procedure. It isn't in any of the posts.
For any rig just go to Google, and search "MARS mod FT-8900" or just "mod FT-8900".
The first post put the idea in my head to paint the knob markings. I am also considering changing the faceplate LEDs to green to match everything else on the dash. I might have the local store do the LEDs though. I don't have a Miniature/MicroMiniature soldering station at the house.
