20" LED hood mounted light bars
Hi Guys
Just a quick question regarding the hood mounting position.
The bottom of the light bar is only about 6" from the hood, i do realise the hood slopes down, but do you get much light on the hood?
Do you need to run Hyper spot narrow beams to miss the hood? or
Do you have to angle them up a little?
I have an issue "seeing" over my hood. I run the seat up as high as it goes.... and i am 6'2".... Do these hood lights get in you way, visually?
Thanks
Regards
Paul
Thanks
Regards
Paul
Run spots if u can try to avoid floods on ur hood.
I'm 6'2" and I run the seat all the way down and almost all the way back. The light bar does get in the way a little
Sent from my HTC6500LVW using Tapatalk
