2008 Radio Died
Old Mar 2, 2012 | 05:51 PM
bbazinet's Avatar
Default 2008 Radio Died
I have a 2008 JK and the radio completely shut off today. I checked fuse M10 and M12 under the hood and they look ok. Everything else seems to work ok just NOTHING on the radio. Any suggestions?
Old Mar 2, 2012 | 11:46 PM
OverlandJKU's Avatar
The radio on my 2007 stopped working one day. A few days later it started working again. It was just before the battery failed... Do you have the original battery still?
Old Mar 3, 2012 | 04:05 AM
jeepguy553's Avatar
Yep...I had a similar issue a few days ago. My radio started acting weird...then the factory battery crapped itself. Battery replaced...problem gone.
Old Mar 3, 2012 | 08:10 PM
rumnreggae's Avatar
Default Tempramental RER
My Navi has a mind of its own. It frequently will lose volume control after starting. This ever happen to anyone?
Old Mar 3, 2012 | 08:13 PM
jeepguy553's Avatar
Yes. It usually comes back. I have had it decide not to turn on and found out that disconnecting the battery briefly at the negative side then reconnecting it fixes the problem. I have no idea why it does that but would love to know.
Old Sep 13, 2012 | 08:38 AM
Twofeatherzs's Avatar
'08 X bought it new
My first radio went out on Feb. of 2011. Was replaced under warenty.
Now over the weekend, it went out again, 09/08/2012. It is at the dealer now. I checked the battery both times. The battery is fine. The dealer told me that this is a common issue if you have the normal, bottom of the line radio. If this is a common issue, then why does jeep use a cheap radio. The dealer also said they will try to get it covered under the extender warenty. We will see.
