2012 daystar lower dash switch panel
Old Feb 22, 2012 | 02:47 PM
anonymark's Avatar
Yea, that "for automatics only" was not there when I ordered yesterday. Crap. I still wonder if it will work once it's in? If not, then I'm cutting the darn thing up and putting it above the mirror.
Edit: I can't get the stock panel out either, seems to be stuck at the bottom....
Old Feb 22, 2012 | 02:54 PM
krzfirefighter013's Avatar
to get it out you need pop up the center console around the shifters ..just pops straight up ....i had to remove mine to install
Old Feb 22, 2012 | 03:26 PM
anonymark's Avatar
Well that was quick. Got the stock panel out, that was easy. Just "pop" the entire assembly up around the cup holders and shifters. That front piece is just clipped in. No need to pull of the transmission case knob, I just shifted into 4 high....
Bad news, There is no way the panel works with a manual. I can get it in, but you can't put that front piece back in and you can't shift into 3rd. I took it right back out.
Dremmel time for the upper mirror mod.
Edit: krzfirefighter012 beat me to it "to get it out you need pop up the center console around the shifters ..just pops straight up ....i had to remove mine to install"
Old Feb 22, 2012 | 03:44 PM
i got mine in my maual but its a tight fit
Old Feb 22, 2012 | 04:17 PM
anonymark's Avatar
Attachment 281173
Wow. I'm eating crow now. Looks like I'll be back in the Jeep come first light. Do you have any problems shifting? For the life of me, I could not get the center console to get in around it......
Old Feb 22, 2012 | 04:29 PM
i had to remove the center console and then install it the put it back ...with the shift boot tucked down i drove all over and went through the gears and no problems as of yet
Old Feb 23, 2012 | 11:20 AM
anonymark's Avatar
I got the Daystar in with some jimmying. I had to remove the center console (just the front part), and then completely remove the manual shifter boot. I put the center console back in and slid the Daystar in. I I pushed the boot back in from the top and clicked it back into place. I'm having no problems with it hitting yet.
Daystar with shifter down in 3rd
Daystar in 5th. I need to put the boot down
I'm still thinking the upper visor mod might look nicer.....
Old Feb 23, 2012 | 01:19 PM
if you push the shift boot down in like i did in my picture it does not interfere with the switches at all
Old Feb 23, 2012 | 03:02 PM
anonymark's Avatar
I did that right after taking the pictures! It works fine, if a little cramped.
If anyone from Daystar is watching this thread.......To make it work in a manual without issue, all you would have to do is change the angle of the switch plate a bit and it would work fine.......
Thanks krzfirefighter013 for figuring out that this would work.....
Old Feb 23, 2012 | 03:04 PM
no prob im glad i got it to work fork myself too ....let me know if you think of anything to refine it
