2013 with fan blower noise
Old Nov 6, 2012 | 11:16 AM
GoRemote's Avatar
Default 2013 with fan blower noise
My unlimited rubicon is less than a week old, and this morning the fan (heater/ac) started to sound like a 2 stroke outboard... Anyone with the same issue?
It works fine, just making noise.
Might be a leaf..
Old Dec 26, 2017 | 07:00 PM
nipcakes's Avatar
Ever find out what this was? Mine just started making a noise tonight.
Old Dec 26, 2017 | 07:54 PM
tjkamp's Avatar
Check the in cabin air filter. Drove me nuts trying to find what it was, finally found I had a torn filter.
Old Dec 27, 2017 | 05:44 AM
resharp001's Avatar
Loved
Community Favorite
You might just pull the glove box out and make sure nothing is stuck in the blower. If you open the glove box, you should just be able to pinch the tabs in the rear of it in and it will come right out allowing you to see behind it. I just took mine out for a different reason, but noticed some napkins and other crap that had fallen down behind it and blocking some of the air flow to the blower.
Old Dec 27, 2017 | 06:05 AM
ronjenx's Avatar
Mine started making noise years ago. After looking for the things mentioned above, I decided it was a problem with the motor.
Sure enough, the commutator and brushes needed dressing, and the brush holder was dirty with carbon dust.
Here are two pictures showing what it looked like before cleaning things up.
Name:	Brush Holder.jpg
ID:	676774   Click image for larger version
