3rd brake light
3rd brake light
Who moved the 3rd brake light when you put a tire carrier on? How did you run the wiring? Pics would be good... just looking to see how everyone ran their wires or brake like position.. thanks
I have the TF hinge and carrier. I used the extension to lift the 3rd brake light up to clear the tire. The wire will reach. I just took this picture yesterday while test fitting a rear camera/3rd brake light piece I've been developing. When it's ready I'll just reroute the stock wire. I'm assuming if you did a bumper mounted swing away tire carrier some lengthening of that brake light wire might be involved. You can also pull it back through the tailgate into the rear fender behind the taillight and then go anywhere you want with it, likely out down by the frame rail to come up inside the rear bumper. I rerouted all my rear wiring through the fenders and there is plenty of room back there and lots of options depending on your setup.
