50" light bar fix
Old 11-25-2014, 06:54 PM
Jeep-Junkie34's Avatar
Default 50" light bar fix
Currently have a 50" light bar installed that I had to modify to have it stay on my bracket, I reversed threaded bolts but the bolts are currently loose on the light. Is there any solution to this?
Old 11-26-2014, 08:07 AM
TheNoob's Avatar
So your threads are stripped? You can stick a small zip tie in to the hole and then screw the bolt back in. Then just cut the excess zip tie hanging out. I had to do this on mine because I stripped one side. Works like a charm.
Old 11-26-2014, 09:31 PM
Do you have any photos of what you're saying?
Also I've tried JB weld and even gorilla glue but it all just broke loose and the light just moved around
Quick Reply: 50" light bar fix
