7" projector head light
Jason, there are a few different ways to do it on a budget.
Look for "6024" or "Hella 6024" or "Sylvania H6024". You can find those in $12 - $50 price range each. Pay as much as you want. That will replace the reflector which some people think is the first problem with headlights.
That will also change your headlight type to H4 from H13 so you will have to make or buy an adapter. That is about $50.
Finally you will need bulbs. You can get any wattage H4 bulb or you can get a H4 HID kit.
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/headlight-options-81868/ has a complete shopping list at the end.
I definately can't answer these detailed questions as I am simple minded. Screaming Lizard Customs sells them and can help you out with those questions. They are brand new and developed by one of our north Texas members. These are true HID systems, and not just cheap bulb replacements. Compared to stock, you don't even need the high beams. These are setup so that the light itself is always constant. High beam actuates a focusing 'shade' around the light to allow it to spread out further.
Yes...I have the SLC ones. They are true projectors. You won't be disappointed in the light output. I can't even tell that my stock fog lights are on when these are on.
