7" Touchscreen Head Unit on 2008 JK
Meaning this: http://cgi.ebay.com/ws/eBayISAPI.dll...m=220375062733
And did you have to get the Metra XSVI-6522 harness? http://cgi.ebay.com/NEW-METRA-XSVI-6...3A1%7C294%3A50
I'm looking into the Eclipse AVN-6620 with the PAC Steering wheel adapter, Ipod connector, and a backup camera for $500. Then a speaker upgrade.
that is a nice unit. I had an avn 5435 in my tj which is very similar. I acutally told someone just yesterday to buy this unit for his saturn, and he did. It does not have a hard drive, but it has the mad on dvd and the unit has 2 dvd drives. so you do not have to take the map disk out to play a movie. I think it has a memory card slot for mp3s, and you can put a ton of songs on a DVD and leave itin the other drive. Plus eclips is real ez to make play video and have data entry while in motion. I saw them on ebay for under 700 with parrot BT kits.
You will need a double din adapter, but they are cheap. All it is, is two little plastic tabs to fill the space on either side of the unit. You may have to hack a little on the inside of the dash, but not much. There are some write ups about it on here.
I say go for it! That is a good company, and a nice unit. Amazing price. The new hard drive eclipse is 2 grand.
do you have the infinity system now?
No, I don't have the infinity system. Just basic stock. I bought the double din adapters already. I don't understand where the sub is in the car. Is it in the dash? My '04 had it in the middle console and I took it out and but a much stronger one in. I would have to look around to see what people have done with their subs. I really don't want to put something in the back. I finally have a trunk in my jeep and need as much space as I can get.
If you have any questions feel free to PM me as well. I am no expert, but I have been messing with car audio/video since mid 90s.
I am getting ready to replace my HU and saw on here that the METRA XSVI-6522 will work with connecting the HU. I tried to order one through crutchfield at the same time I was going to order the antenna adapter and mounting bracket and they told me the METRA wouldn't work and I should go with the PAC's C2R-CHY4 which runs $129 . I saw here and on other forums that the METRA should work. So should I be concerned if I buy the METRA harness or go with it and don't worry about it?
Just need a little confirmation before I buy the harness and of course I figured I could get that here.
Thanks
Thanks
I bought mine from crutchfield and they supplied all the adapters for free and the harness for half price. The only hard part about the install is fitting all the wires in that little hole when you're done. You will also need to use a sawzall or sometype of cutting device to cutout part of the bracket so that the top of the unit will fit in.
The Eclipse unit is nice also because you can just ground the parking brake wire and watch video. The built in GPS works really well too.
