adding oem power windows and locks to 14 JKU HELP!!!
Old 05-19-2017, 06:03 AM
mnoble616's Avatar
Default Power locks
You can find the 2.8mm terminals for the power windows and locks at theelectricaldepot.com. They are not exact(just a little taller), but they fit in the oem connector and lock in place. They stick out of the top of the connector a little but there is no way for them to short out on anything as long as the connector is put back in its original spot. I bought 50 of them to have and used them to install OEM power locks using an aftermarket keyless entry module to make them work on a 2016 JKU.
Old 06-26-2017, 06:43 AM
mikem302's Avatar
Default direct link
Hello, Would you be kind enough to provide the direct link from theelectricaldepot.com. I was searching and got overwhelmed with the results. Thanks. Just ordered the OEM power latches and harness and will soon start the project
Mike
Old 06-26-2017, 07:17 AM
mnoble616's Avatar
[QUOTE=mikem302;4296604]Hello, Would you be kind enough to provide the direct link from theelectricaldepot.com. I was searching and got overwhelmed with the results. Thanks. Just ordered the OEM power latches and harness and will soon start the project
Mike[/Q
theelectricaldepot.com/index.php?main_page=advanced_search_result&search_ in_description=1&zenid=03c71e827594c90f5916312decd de529&keyword=54001801&x=9&y=4
This will take you to the exact item. For the rear hatch lock I converted the old plug to a four connector plug by drilling out the back of the plug and cutting two wires from old front door harness and using them as my connector.
Old 06-26-2017, 07:49 AM
mikem302's Avatar
[QUOTE=mnoble616;4296606]
Mike[/Q
Perfect! and thanks a million. For now just doing the 2 front doors. Then will tackle the rest.
Old 11-04-2017, 04:53 AM
COMike's Avatar
Thumbs up
Thanks for posting this, just what the doctor ordered!
Old 04-16-2018, 11:41 AM
rickyc1999's Avatar
Question Need help with upgrading to oem power door lock wiring on 2015 JKU
Hi,
Can anyone help with the wiring who have upgraded their JKU from manual to oem power locks?
Did you replace the wiring harness in all four doors or did you utilize the existing harness, and just run additional wiring from the power actuators? Also I have the 18g Female and Male connectors, part #s Terminal-18 Gauge Female - Mopar (68316927AA) and Apex 2.8 Male Unsealed Terminal (ak Delphi 10762775); Did the male and female components fit into the quick connects in the door and body sides, or was there any additional challenges that I have not accounted for?
Once the quick connects are wired and connected on both sides, the body side door wiring will routed to the aftermarket security system to complete the circuit.
One other question, can I use the existing connectors to the manual door actuators, and just wire in two additional cables for the power actuators... or will that not work?
Quick Reply: adding oem power windows and locks to 14 JKU HELP!!!
