adding off road lights
Old Oct 14, 2008 | 03:35 AM
  #21
jeepnyak's Avatar
i pre wired the lights through the bar and the whole set up is waiting to be reinstalled once i get back from branson. i will be there a few days.
What i did was wired the the 2 left lights together and the two right lights together. left have 1 black and 1 blue wire, the right have 1 black and one blue wire.
Should I:
A- wire both to the existing wiring harness (when they were pillar mounted)
B- wire one set to the existing, and one to a new setup(relay, switch...)
Old Oct 14, 2008 | 05:01 AM
  #22
Frog Rubicon's Avatar
I like the Mopar Hella; looks very nice
Old Oct 14, 2008 | 08:15 AM
  #23
Littlejon's Avatar
Originally Posted by N2rock
Depends on the wattage of these lights, and how much the existing relay can handle. I know the relays that came with my KC Slimlights are just adequate for the 2 lights, any more than those 2 lights would be more than the relay can handle.
Safest bet would be to just do each set separately. If your goal is to have only one switch, you could still trigger both relays with a single switch.
I think he should be ok with a 30 amp relay since it is 4 55 watt lights.You should only be drawing around 18 amps. This is less power than many people are running from a set of KC lights. If the stock harness came with only a 20 amp relay upgrade to the 30 as long as all of the wiring is 14 guage, otherwise use the 2 relay method. I would tie them into the existing harness from your windsheil lights since you don't have the windsheild lights any more.
Old Oct 16, 2008 | 09:54 PM
  #24
jeepnyak's Avatar
thanks guys
Old Oct 31, 2008 | 07:43 PM
  #25
jeepnyak's Avatar
I can't find my relay, these are the mopar hella's
