Additional interior LED lights
Sounds like a 3 way switch would work best for you. This schematic was for footwell lights, one on each side, but you could just do one of them. The switch will allow you to either have it come on with the dome automatically, or never have it come on, or have it come on manually.
For the other 12v feed, if you have a rear cig lighter you may be able to just tap into that. I don't know if it is switched or unswitched since I have a basic Jeep. But if you do have the rear cig lighter, it is switched if the cover has a picture of a key on it and unswitched if the picture is a battery.
Edit: I redrew it for you.
I wired them into the dome light circuitry, both left and right, and they come on when the door is opened and fade out when the dome light goes out. The left light also comes on when you hit the left dome light button and the same for the right side. It's a big improvement because it puts the light where you need it.
