Aftermarket Foglights
Old Feb 17, 2013 | 03:55 PM
ToolManTimTaylor's Avatar
I have the "wide" beam kit. Its a direct fit replacement for OEM jk holes. My fan fours front bumper also has OEM size holes and mounts so they fit perfectly. Check em out Vision X
Old Feb 17, 2013 | 03:58 PM
k0260's Avatar
I have some searing bright LED reverse bulbs for my reverse lights, from V-leds. I'm wondering if anyone has used their fog light led bulbs? They're a hot item, so right now and often on back order, but thinking of buying a pair when they're in stock again. $59. Surely there's someone here with these or comparable bright led bulbs in fogs???
Old Feb 17, 2013 | 04:22 PM
Forgot to mention they draw less than the factory fogs. Yeah pricey but we spend more money on things that we use less or are not a mod that will get used every day.
I am curious I gotta say. Led fixtures have reflectors built into their housings designed for led bulbs. Standard housings reflect light for the use of incandescent bulb age. Most led bulbs on the market do not use have nearly 360 degrees of light output like astd bulb does. Sure some have rearward firing diodes to bounce off the reflector but still rely on a powerful spot led that faces forward. The technology just is not there yet for bulbs that need to fit smaller openings like our fog lights. The OEM reverse light openings are large in comparison to the fogs and can utilize the current(no joke there) technology.
