Airbag light
Old Jan 17, 2012 | 05:31 PM
Bigbender's Avatar
Default Airbag light
Is there a way to reset the airbag light? I took the seats out (2010 JKU) to put bedliner in. That went well, but when I put the seats back in, the airbag light came on. Apparently the airbag light cannot be read or reset by a normal reader. The guy at pep boys read the code for me for free, seatbelt retractor ground was not making full connection, but he would not reset the code for liability reasons. I fixed the ground and am pretty sure that nothing is wrong with the airbag, just want the light to go away. Any suggestions?
Old Jan 17, 2012 | 05:57 PM
ScruffyRubicon's Avatar
Not sure if disconnecting the battery for 30 minutes will clear this one or not. Might also try disconnecting battery and shorting positive and negative leads.
