Anyone install a tweeter in the soundbar? Any advantage?
They're JL Audio C5-650's (2 sets). If you listen to music at reasonable levels, then these speakers should supply decent bass. If you need to "feel" the music, a sub would probably be necessary.
I'm still planning on adding a JL HD900/5 and a small JL sub (probably 8") to add some punch, but I don't want to announce my arrival 5 minutes before I get there, if you know what I mean.
Not a huge fan of tweeters in the soundbar just because it is too close to my head. Getting a 3way speaker in the front speaker pod is a much better option and stay with a 2way in the soundbar.
Proper equalization also helps a lot.
Originally Posted by mkrx5
that's a great JL. Ive seen that people have put 2 or 3 ways in the front, however with the additional tweeters on dash, i think the highs would overpower everything else.
Did you have to modify the soundbar at all? Also, how are you powering the tweeters? I have an Alpine PDX-5 powering my 4 speakers and sub. I'm thinking I can just power the tweeters off my Aplime UTE-62BT headunit.
I did, only because I got a great deal on the speakers. Actually, it came out better than I thought it would...crossovers are mounted inside soundbar, and you can definitely hear the difference with the tweeters in the soundbar.
Here's a couple of pictures:
The tweeters can also be aimed for optimum fine tuning of the sound.
