For anyone intersted in aftermarket Power Windows
Old Jul 20, 2009 | 12:23 PM
  #31
fighterpilotmav's Avatar
lol no no no only when you stick the key in the door and turn and hold it in the unlock position will it roll down the windows... but most of the time you use the key fob to unlock the doors so the windows wouldnt go down unless you put the key in and turned and held it....
Old Aug 27, 2009 | 07:04 PM
  #32
feroxjb's Avatar
Nope.. it's just the power window kit period.
This option can be installed if you get an alarm/keyless entry kit with that option in it. There are several for sell that do this.
Old Aug 27, 2009 | 10:03 PM
  #33
Firehound's Avatar
Is it possible to use the wiring from the kit with factory power door wiring? I thought I read somewhere that you need a whole new harness + a comp flash, so by using the stock door wiring and the kit wiring, wouldnt that eliminate the need for the harness and the flash and is it possible? I might do a door swap, problem is I have dont have power, the other doors are powered. Any thoughts ideas would be great
Sorry for the hijack
Brian
Old Sep 15, 2009 | 10:36 AM
  #34
maxx2308's Avatar
I'm looking at adding the 2dr power windows to my JK but want to mount the switches to the center dash like the 4dr version...but it looks like the 2dr kit only comes with the door mounted switches. Does anyone know of an alternate switch that can be mounted in the center dash for the 2dr kit?
Thanks,
Maxx2308
Old Sep 15, 2009 | 12:36 PM
  #35
SlyStevie's Avatar
Originally Posted by jeepin08
looks better than the factory switches!
I agree.. I'm kind of jealous...
Old Sep 16, 2009 | 11:35 AM
  #36
JTG's Avatar
JTG
I started installing my Electric Life 4-door kit last night So far it's 10,000x easier that trying to mount the lock actuators.
Old Jan 19, 2010 | 11:59 AM
  #37
Toro34's Avatar
So I just went car shopping for my friend and we stopped at the VW dealership. They showed us this cool feature of when you put the key in and turn it, it rolls down all the windows.
Is this kit programmed to do that or is that an option? Is there any aftermarket power windows that could do this?
I do like the look of this kit but I would get the factory switches for the front inbetween the air ducks to make it look for factory...
sorry for the old thread revival, but look up a DEI 530T
power window module. u can connect it to your alarm and roll up/down the windows with ur key fob
