Anyone Know of a wire I can tap into.
Anyone Know a wire that I can tap into so that when I turn on my headlights the writing on my E locker switches turns on? On the actual switch its pin 7 for negative and 6 for the Accessory power. But I don't want to tap into say something like the Radio because then My Locker switch writing will be on when I turn the Jeep on.
Any help would be appreciated. Thanks
Pins 8,2,3 are being used for the actual actuation of the locker.
STEDI Blog - How to wire LED Rocker Switch | 5 pin
I got this pinout from our Australian Friends "Down under"
Thanks
For the switch lighting?
Edit: Now I know what you mean. I thought you were talking about the locker indicator ground at the dif for a Rubi. You can jump pins 7 and 8 together and run them to the nearest ground lug, like the footwell. Pin 6 to dash light source so it dims as well, pin 2 is +12V (switched or unswitched depending on your needs), pin 3 out to relay trigger (pin 85 or possibly 86, depending on how the relay is wired).
Hazard Light power
I think I'm going to tap into the hazard light power. The button light only turns on when you turn the headlights on.
Here is a picture of it. The larger plug is the HVAC. The smaller plug is the Hazard light and TC switch.
Anyone Know what one is the Headlight Hot? I pretty sure there is a constant hot for the button when the headlights are off because you would not be able to use them without the headlights on.
