Attenna
Old Oct 10, 2011 | 12:55 PM
Mikey214's Avatar
Default Attenna
How will the reception be if I cut down my stock attenna?
Old Oct 10, 2011 | 01:00 PM
Titanium Dad's Avatar
I bought a black stubbie antenna. Was only like $10 on ebay. Didn't think you could cut one down and still work.
Old Oct 10, 2011 | 01:08 PM
Mikey214's Avatar
Some one on here did it before
Old Oct 10, 2011 | 01:50 PM
Mikey214's Avatar
Bump anyone ?!?!
Old Oct 10, 2011 | 02:17 PM
Delux2769's Avatar
You can pop the ball off the top of the antenna and reattach it after cutting down to 8-10".
Signal will be 98% of long antenna.
Old Oct 10, 2011 | 02:52 PM
Mikey214's Avatar
Do I have to cut it down any certain way ?
Old Oct 10, 2011 | 03:03 PM
Delux2769's Avatar
I used a pair of pliers and snipped the antenna, then slid the pliers hard down the shaft and popped off the ball. Got a dab of glue on tip, then stuck the ball on shortened stick.
Hope this helps.
Old Oct 10, 2011 | 03:39 PM
Mikey214's Avatar
Hope this helps.
How's the reception ? And thanks!
Old Oct 10, 2011 | 03:50 PM
Delux2769's Avatar
Reception is just fine if you put on the ball on the tip. It won't be as good if you forget to put the ball tip back on, just warning.
Old Oct 10, 2011 | 05:15 PM
jeremy550's Avatar
I cut mine with a dremal to about 10 inches and rounded it off instead of reattaching the ball. Seems the reception is about the same.
