Auxilary Driving light question
I need to get two driving lamps for my 07 rubi. I spend time driving to and from Alaska and need to see beyond the stock high beams. I was thinking PIAA and was wondering if I could somehow have the lights wired so when I activate the high beams, the driving lights would come on as well. Is this possible?
Yes, it is possible.
Did you get the PIAA wiring harness as well? If you did all you have to do is get rid of the switch. Instead of having a switch you would tap the high beams and have them trigger the relay turning the lights on.
Do a search for "high beam trigger" and you will find a few diagrams of how to wire it.
i wired my windshield mounted hellas to my high beam switch by simply running the wires to the windshield lights positive cable off of the power inlet to the high-beam portion of the headlamp itself. did that make sense?
if a headlamp has hi beams and low beams in one housing - like the jk - it has twopositive leads going into the light housing. igure out which is the high beams and run your auxillary light positive off of that lead. your aux light will be grounded to the frame wherever you attach it
Here in Pa it would not be a good idea to have any aux lights above the headlight wired in directly. They must be covered anyway, when onroad.
I think that I've heard that the Lightforce lights are very popular up there, you may want to check into them, I'm getting two pairs of the 170's. Wiring them into the H beam is easy but I never liked it that way , I would rather have more control. I have found that there are some situations like a light fog or mist where the lows aren't enough but the highs w/ the aux lights are to much but because there wired together you're screwed cuz' the h beams alone would be just right.
I have the Lightforce 170 and the harness that is also Lightforce... I love them!!! the only thing i had to do was change the switch to an LED switch but that was a personal choice i made. the install was vary EZ!!
I went the other direction and powered mine separately so that I can activate them whenever I want.
I used the supplied PIAA switch. Since I didn't want to cut and resplice the tiny wires inside the switch wiring, I had to pull that big thing through the firewall which was a big pain (most time consuming thing of the whole project). I would probably cut the wire if I had to do it again. Let me know if you have any questions, I can probably snap some pics if you need them.
Thanks for the reply that was one option I was thinking of and it works great so far... but... For some reason now I lost my factory fog lights
So it looks like I have a project for tomorrow night after work... Anyone have any ideas?
