Auxillary Light Switch Question
So, I have four aux lights switches on my pillar. Just changed them out from a 3 pin on/off switch to a five pin on/off switch. One of the pins is for:
"Connect #6 to your dash light circuit or ignition to be on when your dash lights are on or when you turn on the engine (lower light)." Question: Where exactly can do I connect these to? As you can see in the picture, the words on not light up. http://img.photobucket.com/albums/v2...ps2b0c4645.jpg |
I think for that you can tap into the fuse box using a fuse tap so that the lights only work when the key is in ACC/ON position
Not sure what year your Jeep is, but maybe this fix will help ...
http://forum.aev-conversions.com/showthread.php?t=4149 |
(Post 3982750)
Installing backlit Contura switches on sPod - American Expedition Vehicles - Product Forums Great write up...I need to figure out if I can use that dimmable circuit. Not sure exactly where it is...somewhere behind the lower dash. I'll check it out tomorrow. |
Originally Posted by Chief_Airborne
(Post 3982784)
Thanks, Mark. It's a 2009 JK. Great write up...I need to figure out if I can use that dimmable circuit. Not sure exactly where it is...somewhere behind the lower dash. I'll check it out tomorrow. |
(Post 3982808)
Be sure to post back. I have yet to wire up my sPOD for this. ;-)
From your description that sounds like the ACC switch and not the dimming circuit. One of the other prongs would be the dimmer.
You can run a fuse tap, or if you feel lazy, run a line from your cig. lighter. |
1 Attachment(s)
(Post 3982826)
Well, I don't have a sPOD, but I'll let you know how it goes.
Attachment 576073 |
Well, I figured it out...at least for me. I slept on it and woke up this morning remember that I had installed a power tap into my cig lighter that I wasn't using anymore. Duh! Works like a charm now.
Not sure how bright they are at night....I'm sure it won't be that bad. |
On my 2014 there are leds in the cupholders with the wiring connecting under the passenger seat so it would be easy to tap that. On the earlier models, one would have to find which wire on the connector for the instrument cluster, the radio, or the switch bar is for the lights. I'll be adding a switch for my winch solenoid this weekend and I'll see if I can find the one for the radio while I'm at it and post back here.
My sPod has the dual led switches but the lower led is activated by a push button on the spod itself. I may see if I can just replace the power to the pushbutton with a feed from my dash lights. |
