Originally Posted by 14Sport
(Post 3983503)
In the link he says it's the same for the 3.8. |
Yeah I used the same wire on the 3.6 and the 3.8 so it is there (if you have p windows). Most manf. have the harness somewhere in there to save on costs so they don't need to remake a bunch of wiring harnesses. A portion of it might be further in the dash? The other option is in the driver footwell as the wire is also in there, but due to the pain of crawling under there I've never investigated as the dash is easier to work on.
Originally Posted by Vladimer
(Post 3983565)
(Post 3983571)
Would you happen to know if it's the same color, orange/grey, in the footwell?
(Post 3983653)
From what I remember reading on the forums it was the same color, but that would be the extent of my knowledge on the footwell portion of the wire, sorry.
(Post 3983060)
And I'd like to rewire the existing sPOD lights switch to be an sPOD function switch--disable all sPOD switches unless that is turned on. This would prevent something silly like inadvertent actuation of the front locker while tooling down the Interstate at 75 MPH, LOL ...
Since there are 6 individual circuits coming in, the only options I see is to use the sPod button as a trigger for: 1. 6 SPST relays or 3 DPST relays, or 2. 1 DPST relay just for the lockers specifically, or 3. 1 solenoid between the battery and sPod feed. Not sure of any better way to do it but I'll keep thinking. |
