B1477 Amplifier Issue
Old May 15, 2022 | 09:08 AM
EHarris's Avatar
JK-Forum Ambassador
Default B1477 Amplifier Issue
I have an 08 JKU and at the time in 2008 the "trend" was to pull the stock amplifier out and put in the Dodge Nitro amplifier which had a little bit better sound and power. Recently, I've been getting B1477 check engine code which is Channel 5 Audio Speaker Output Circuit Open. If I move the balance all the way to the rear there is almost no music playing. Only the front seems to be working. I am assuming the amplifier has finally went after 14 years. I'm looking for a fix or a cheap replacement. It seems like this amp is on Ebay for $100 and I'd rather not spend that right now. I can't seem to find it new on RockAuto or anything.
Any troubleshooting or does anyone have the old stock amplifier that could be a direct replacement for me? Thanks in advance.
Old May 20, 2022 | 05:53 PM
EHarris's Avatar
JK-Forum Ambassador
Bump to the top.....
Anyone have an old JKU amp in the garage they are willing to part with?
Old Jun 12, 2022 | 06:40 PM
EHarris's Avatar
JK-Forum Ambassador
Bump to the top. Anyone with an old amp just sitting there. $$$$
Old Jun 22, 2022 | 09:14 AM
CJ's JK's Avatar
Veteran: Navy
Default Original Infinity Amp
I have the original Infinity amp out of my 2011 JK Sahara which you can have if it will fix your problem.
2011 JK Infinity Amp
