Best wiring route through 2015 JKU firewall?
Old 10-12-2014, 03:43 AM
14Sport's Avatar
Here's the passenger side one.
Name:	Winch Solenoid 003 (Medium).jpg
Old 10-12-2014, 05:40 AM
ade
ade's Avatar
Originally Posted by nhfd21348
Is yours auto or manual?
Automatic
Old 10-12-2014, 05:48 AM
catahoula's Avatar
This will give you a picture of an option to run wiring.
Rock Lights - Walmart Platinum Burner Installation Write-Up
Old 10-17-2014, 12:04 PM
nhfd21348's Avatar
Okay I got the wires through the fire wall and tried to run the lights from my lightbar underneath the bracket and there is not enough space. Any ideas are welcome.
Old 10-17-2014, 12:15 PM
darkknight1999's Avatar
What size wire are you running? Mine fit back there no problem... You have to run the wire with the bracket loose. Then tighten it down... It's kind of a pain
Sent from my NSA monitoring device... Using the JK-Forum app
Old 10-17-2014, 12:22 PM
nhfd21348's Avatar
12 gauge
Old 10-17-2014, 01:15 PM
12 gauge
What is the outside diameter of the wire?
This is mine:
ID:	580209   Click image for larger version
ID:	580210   Click image for larger version
ID:	580211   Click image for larger version
Old 10-21-2014, 08:32 PM
nhfd21348's Avatar
What is the outside diameter of the wire? This is mine: Sent from my NSA monitoring device... Using the JK-Forum app
Sorry about the delay been hectic at work lots of people taking vacation. There is no way to run them behind the brackets the brackets do not leave the room that is on yours it's a real pain in the but. I still haven't found a way to run them yet.
Old 12-23-2014, 09:20 AM
2015XX2's Avatar
Default Best wiring route through 2014 JKU firewall with manual transmission?
I have the same issue, but unlike your automatic, where you went through the firewall is my clutch. Any help from anyone is greatly appreciated. I am waiting on SPOD to reply.
Old 12-23-2014, 11:22 AM
14Sport's Avatar
Just pull the side panel off the dash and go through the hole filled with Styrofoam. This is the passenger side but the drivers side is the same.
Quick Reply: Best wiring route through 2015 JKU firewall?
