blinkers fast, where doninput resistor(s)
Old Nov 15, 2012 | 07:36 PM
Jersey_Devil's Avatar
Default blinkers fast, where doninput resistor(s)
So I changed all my exterior bulbs to L.E.D. compatible bulbs and I had to take out the rail lights cuz with the lihts off, if I used a blinker all lights blinked, so now with regard bulbs ONLY in taillights they just blink fast.... Where and how many resistors do i need?
Old Nov 16, 2012 | 10:11 AM
Bump.........
Old Nov 16, 2012 | 10:39 AM
jchmelojk's Avatar
if you just have led for turn lights, one resistor per tail light
Old Nov 16, 2012 | 11:06 AM
lewisonupland's Avatar
If you have all 4 turns done then you need 3 ome resistors if you did fronts OR rears you need 6 ome resistors, one for each
Old Nov 17, 2012 | 05:56 AM
So then I should get (4) 3 ome resistors?
Old Nov 24, 2012 | 07:01 AM
Bump......
Old Nov 25, 2012 | 06:20 AM
I think you only need two but check on the v-led website
Old Nov 30, 2012 | 03:51 AM
Thank u, I will!
