Can The Sirius Signal Be Increased on a 430N Unit to avoid it cutting out?
Old 06-06-2013, 03:46 AM
BNS4X4VR's Avatar
Default Can The Sirius Signal Be Increased on a 430N Unit to avoid it cutting out?
The 430 N unit work fine but the signal form Sirius cuts out. Is there any way to increase the amplify the signal?
Old 06-06-2013, 04:32 AM
Mattk11's Avatar
Move your antenna. It's above the passenger front seat. Aftermarket soft tops kill the signal and sometimes the hard top will cause problems.
Old 06-06-2013, 04:24 PM
Kojack's Avatar
Where do you suggest? There is no place to put an aftermarket antenna.
Old 06-07-2013, 06:12 AM
CoreyZ's Avatar
Move it wherever you want. Aftermarket antennas wont work.... but the stock one can be placed anywhere really. Heck I even previously suggested making a magnet base for it since the bottom of the antenna is just some plastic holding in a bolt. Some people have moved it to the grill on the hood in front of the windshield (between the wipers).
Old 06-07-2013, 08:13 AM
Kojack's Avatar
Mounting it down low like that will not make a difference. Needs to be higher.
Old 06-07-2013, 09:59 AM
CoreyZ's Avatar
Higher is better, but as I stated... its where others have moved it and with great success in reception.
The main issue with the antenna in the rollbar is the hard top and some aftermarket soft tops as well as the expedition roof racks causing a squirrel cage effect.
Quick Reply: Can The Sirius Signal Be Increased on a 430N Unit to avoid it cutting out?
