Cant find clear answer! Want to add substation but use Factory HU
2014 JKU - Did not have infinity sound system.
I have been looking for awhile now and I can't seem to find a clear answer. I bought a Kicker Substation just to add some bass to stock system. It is a loaded system and I have all wiring. I see people saying you need a converter to use stock Headunit and others say you don't. They say it can mess up the canbus (Idk what that is). Can I keep my stock headunit with this setup? If so, do I need a converter or can I wire the system up to the stock headunit?
Like I said, there are answers out there I know but none of them are very clear and/or there are mixed responses. Please help
I tapped into the rear soundbar speaker wires at the lower b pillar on passenger side. Ran speaker wire from there to rear cargo area then a small converter to change speaker wire to RCA cable and wired up the amp and sub.
sent from the slow lane
Sounds fine. No issues. I just have the gain turned down so not to overpower the mids and highs from the factory speakers. But I can turn it up and bass out if I want to.
I added a Kicker powered sub to mine I tapped into the passenger front speaker behind the glove box,
you should have high level inputs on your Kicker sub (speaker level) no need for RCA adapter and will be able to adjust as needed with sub controls on High use the gain control.
I have read that the rear speakers do not have a full range signal all the time and the front is a better option for a sub, don't know but I read it on the internet so it must be true.
The amp input has 2 sets of high level inputs. Do you need to run cables from both of front speakers or can you run both inputs off of one of the front speakers?
I only used one.
Sub frequency is normally mono, not always but most of the time.
I suppose both may be better but not sure, if using both make sure you get them in phase, + to + - to - (jeep wires to sub amp wires you will need a wiring diagram) on both (all 4 wires) inputs then you can effectively use the phase switch.
If using one, the phase switch on the sub amp can also be used to get them in phase with the rest of the speakers in the jeep.
only use one set if hooking to just one jeep speaker.
I did the exact same +2 on this post. I still use my stock head unit.
