Changing Headlights
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
IV got an 09 Sahara and was would like different bulbs in the headlights/fogs.
Without changing the housings completly, Id like to change the bulbs for better light.
Which would be recommended?
Thanks.
Thanks.
The H13 bulbs that the JKs use are pathetic. The best bulb you can get for them is... STOCK. There are silverstars, PIAA etc but they will not be brighter. They will look cooler but that's it.
Do it the right way and get some IPF/Hella/Cibie lenses and drop in some H4 bulbs and you will be HAPPY.
The IPF's from Northridge4X4 with the H4 bulbs do a GOOD job and aren't THAT expensive when you consider what it's worth to be able to see at night. That would be my recommendation.
BTW, here's a link that will show you the pattern of the IPF's. It's MUCH better than stock was.
https://www.jk-forum.com/forums/show...ght-Pics-Added
