Cool Headlights
#32
Ooooh, me rikey!!!
The site says they're DOT approved, which means the turn signal should be visible with the headlamps on. (unless they only had them approved for headlamp use)
#33
As long as the other car is smaller the JK does well on head on crashes.. Back on the headlights,, I'd like to see them at night.. Having the turn in the headlight works well on some cars.. The newer MB for one.. you can see those signals even over the bright headlights..
I'm thinking about ordering a set to see how it looks..
Steve
Oh,, and it the 06 and 07 liberty that has the driving lights in the grill.. I can measure them in the am if anybody wants,, the wife has an 06.. I just dont have the replacement for my 07 yet..
Steve
#34
I have procrastinated this mod for over a year. Glad to see BLKRUBI took the ball and ran with it! I think I'm inspired to get it done now.
[IMG][/IMG]
[IMG][/IMG]
#35
Actually, that will depend on the situation and whether or not anyone survives the head on collision. What about lane changes in multi-lane roads and streets? Those alone could be tough in a rear view with the lights and the "night mirror" engaged.
As far as how an accident is written up, the officer is usually not their to see so how the hell his he or she going to write it up as they see it? Plus, if there are severe injuries or death, a major investigation is conducted.
I don't see these as a problem as far as the "bling" factor goes but shouldn't be the only signals and running lights on there.
Who said anything about a Head on? If it was a head on, shouldn't the oncoming vehicle see you, not your turn signals and if it's at night, shouldn't they see your headlights first? That statement makes no sense whatsoever. Maybe it's just me, but I usually turn my HEADLIGHTS on at night and don't run with just my marker/turn signals on. I also try to stay in my lane, not driving in oncoming traffic. As far as the police office writing it down as he "sees it", it was a figure of speech. The few times that I've been in a accident, the officer qustioned the involved participants, usually "investigating" the accident to determine how, what, and why it happened.
Just as an example, what's the difference between those headlights and these (Nissan 240)?
or these (the Mercedes ones)......
or these.......
or these......
They all have a turn signal integrated into the headlight housing each with location variances. How are they any different?
Gezz, I'm surprised some of you even leave your stinking house for fear of injury. Candy asses.
Yes, right now, I'm running the Mopar Fog lights (the rectangle lights) using my factory wiring and using some other wiring that I had installed to run the Prius lights. Both are operated off of the factory switch, but I will have to change things around. I have 100w bulbs that I'm going to put in the Mopar light and the factory harness won't run that high a wattage (but I'm going to try it first), so I'm probably have to swap my wiring around so the Prius lights use the factory wiring.
#37
If you're headed straight down a 4 way intersection, and somebody is heading towards you in the opposite lane, that other person has The Right of way to turn to his right, or to continue straight. If he wanted to turn left, he would have to yield to you.
I don't see how not seeing turn signals changes the situation. I don't come to a stop to allow a person in the opposite direction of travel to cut in front of me .
And as far as lane changes go, what does that have to do with anything? I am only responsible for what is in front of me, until I'm going to make a lane change. At that point, I'm responsible for what's in front, behind and beside me. If I'm cruising down the highway staying in my lane, I'm not responsible for the man behind me looking to get into my lane .
Granted, a safe driver is aware of his surroundings at all times, I don't see how that changes anything. I see the rear turn signals being of much more importance than the fronts. And alllll of that being said, they claim to be DOT approved, meaning they're legal anyways.
As far as the headlamp mod goes..... . I was looking at what you did for a while now, BlkRubi. Did you just splice right into the stock turn signal wires???
#38
http://www.xtralights.com/index.asp?PageAction=PRODSEARCH&txtSearch=h3+hid+k it+pair&Page=1
3 hid kits ...nice
3 hid kits ...nice
Last edited by Robar; 04-05-2008 at 07:16 AM. Reason: edited non-sponsor link-- see faq
#39
Let's think about this for a second. You have the right of way to stay in your lane, and continue on straight, unless there is a stop signal, stop sign, or yield sign.
And as far as lane changes go, what does that have to do with anything? I am only responsible for what is in front of me, until I'm going to make a lane change. At that point, I'm responsible for what's in front, behind and beside me. I'm not responsible for the man behind me looking to get into my lane .
Granted, a safe driver is aware of his surroundings at all times, I don't see how that changes anybody. I see the rear turn signals being of much more importance than the fronts. And alllll of that being said, they claim to be DOT approved, meaning they're legal anyways.
Thanks for the backing Pigina and Wayland.
wayland, I'm actually running the Prius lights off of a seperate relay and wiring that I had set up for the aftermarket lights that I had in my previous Mopar bumper. The wiring had been just sitting there unused since my bumper swap. I just have the switched wire for the relay tapped into the positive wire for my factory fog harness so both sets of lights are running off of my factory switch but powered seperately. I have those temp turn signals tapped into the factory turn harness which is what the Gen Right lights will be hooked into.
What was this posted for? The Prius lights use 9006 bulbs and the Mopar's use H7's ans are getting matching temp bulbs but not HID's for now. The Hella's use H3's and will get HID's , along with adding another pair to the bumper that will also get HID's, after I'm done with my Gen Right's, my Solid Diff covers, and Expedition 1 skid plate.
#40
1 Post
I'm talking about the guy behind making a lane change the same time I am or a car in in outer lane moving to a center lane the same time I am. That's why you use the turn signals.
Its funny how all you guys conveniently over looked this sentence in my post
