Correcting the Speedometer
So, you all know the problem. Once the bigger wheels are on the JK, how do you put the speedometer in order? I've found that, even with changing the gears, there are still slight problems, which, from what I've found, still leaves about a 10% difference in the speed because of the speed sensor pick up.
Sponsoring Vendor
Off Road Evolution Rep
This is one option for you Andrew https://www.jk-forum.com/forums/showthread.php?t=68655
I would not recommend the ACCUPRO. I have it and there is no support. I have not been able to return settings to stock since day one the way it is designed to do. Reached out to hypertech and they said I need to contact accupro or Procomp.
