dash apart
anyone know how to take the dash apart on a new jk..
i was thinkin about changin the cd player... i looked at the dash to see how hard it would be and couldnt figure out how to even take it apart
from a previous thread:
to remove the radio
1. the flat top above the radio pop out from the front(by windsheild) it pops up from the back and then pulls tword you
2. bottom blank peice infront of the shifter pops out, i had to take shifter trim off to get it all the way out (6spd).
3. remove the 7mm screws from behind both previsoly removed parts
4. pop off the whole dash from top to bottom , its all one peice
5. take out 4 screws that hold deck in
6. see its a can-bus system and there is no video our and get mad.
Be VERY VERY VERY carefull, the hard plastic dash is VERY easy to scratch, o suggest getting plastic pry tools or be extremely carefull
Originally Posted by BeerMonkey View Post
to remove the radio
Or with photos:
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/my-new-stereo-install-non-infinity-alpine-iva-w205-25201/
to remove the radio
- the flat top above the radio pop out from the front(by windsheild) it pops up from the back and then pulls tword you
- bottom blank peice infront of the shifter pops out, i had to take shifter trim off to get it all the way out (6spd).
- remove the 7mm screws from behind both previsoly removed parts
- pop off the whole dash from top to bottom , its all one peice
- take out 4 screws that hold deck in
- see its a can-bus system and there is no video our and get mad.
Or with photos:
this video may help ... shows you have to get your radio out!
http://www.youtube.com/watch?v=bebj-0ynPsg
