Electrical problem
Old Jul 17, 2012 | 12:59 PM
baz0157's Avatar
Default Electrical problem
Anyone know what would cause the windshield wipers to turn on and the fluid to spray for no reason? Also, the flashers and then the horn started and when I turned the jeep off it continued to run! The doors are off as well of that is need for anyone to give advice or opinions.
Old Jul 17, 2012 | 01:12 PM
teh215's Avatar
No idea. Try disconnecting the battery for a few and then hooking it back up.
Old Jul 17, 2012 | 01:52 PM
baz0157's Avatar
I did um hook the battery..it went back to normal and starts up.. However, now my check engine light is on and will not turn off
Old Jul 17, 2012 | 02:21 PM
Rich6700's Avatar
Gonna have to get a code reader. I'll bet its a code for a body control module.
Old Jul 17, 2012 | 02:53 PM
OH9JK's Avatar
JK-Forum Ambassador
You don't need a code reader....
1. To check your Jeep JK Wrangler’s DTC codes, simply insert your key into the ignition, turn it to the ‘ON’ position but do not start the engine. Then, push the key into the ignition cylinder and while holding it in, turn it to the ‘OFF’ position and then back to the ‘ON’ position (3) times straight making sure to end with it in the ‘ON’ position. It is important to keep pushing in on the key to prevent it from catching at the different positions along the way.
2. If you do step #1 correctly, all your dash lights will illuminate and your odometer will show up as a series of (6) dashes. If your Jeep JK Wrangler has any logged in any DTC’s, they will be displayed soon after the dashes appear. Write down the DTC(s) and check it/them against the list to find out what they mean.
3. If your Jeep JK Wrangler has not logged in any DTC’s, the dashes on your odometer will be followed by the message ‘-done-’. Turn your key to the ‘OFF’ position and you will in fact be done.
List of codes:
http://www.quadratec.com/jeep_knowle...rticle-139.htm
Old Jul 17, 2012 | 03:19 PM
jduda's Avatar
It might be your TIPM. Do a google search for JK TIPM problems.
Old Jul 18, 2012 | 12:11 PM
baz0157's Avatar
So the problem is telling me the jeep lost communication with the front control module. (tipm). U0141 is the code I got. Any idea how much a new module is and if it is easy to change?
Old Jul 18, 2012 | 12:27 PM
jduda's Avatar
They are like $450 I think. I just had mine replaced under warranty.
Old Jul 18, 2012 | 12:42 PM
baz0157's Avatar
I called the dealership.. I have 37000 miles on and 08 JK and they told me my warranty is up an not covered!! Just my luck!!
Old Jul 18, 2012 | 02:17 PM
OH9JK's Avatar
JK-Forum Ambassador
I would appeal that direct to Chrysler corp.
