Error Code P2273
Old Jul 24, 2009 | 01:27 PM
southbaydog's Avatar
Default Error Code P2273
Can anyone tell me exactly what this means and what I should do?
"P2273 - O2 Sensor 2/2 Signal Stuck Rich"
Thanks in advance
Old Jul 29, 2009 | 05:35 PM
No one can tell what this means?
Old Jul 29, 2009 | 05:44 PM
ronjenx's Avatar
Paraphrased from the manual:
The PCM monitors the downstream O2 sensor. If the PCM does not detect a rich to lean switch within a specific time during a decel fuel shutoff event, the monitor will fail. Two trip fault. Three good trips to turn off the MIL.
Possible Causes
OXYGEN SENSOR WIRING OR CONNECTORS
O2 SENSOR SIGNAL CIRCUIT
O2 SENSOR RETURN CIRCUIT
2/2 O2 SENSOR
POWERTRAIN CONTROL MODULE (PCM)
Old Jul 29, 2009 | 06:47 PM
Originally Posted by OlegFl
did you recently install a cold air intake???
Not recently a little more than a year ago, but yes Airaid.
Old Jul 29, 2009 | 08:13 PM
ronjenx's Avatar
Thanks in advance
Just redirecting you to post #4, in case you missed it.
Just curious; does the cold air intake get its air from under the hood, like the OEM intake does?
Old Jul 31, 2009 | 05:26 AM
Thanks for your help!
