fog light fuse?
i have a pair of aftermarket fog lights and they stopped working last night. it's a pain in the butt to check or change the bulbs, so i wanted to check the fuse first. the fuse that came with the fog light kit is ok.
they should be wired so that the power for them comes from the battery via a seperate relay to avoid that problem.
I suspect this is the same problem most people have, your fog lights are likely to high of a wattage to operate directly off of the factory wiring. The computer reads a problem and shuts them down. I think the stock fogs are 42 or 45 watts. anything higher "might" work briefly before the computer reads an error.
As mentioned above, recheck your grounds, they are a source of many headaches.
I have popped a fuse inexplicably on my KC's twice, I cannot track down the problem but i put in a new fuse and everything operates and tests correctly (I am guessing intermittant short but i cant locate it) My lights are NOT grounded at the bumper as some people do, I had issues with that so i am grounded at my relay under the hood.
Tell us your story.
