Front Turn Signal Wiring
Does anybody know what color wire does what for the front turn signals? I have a 2013 JKRU and just bought the Go Recon smoked LED lights, there is a resistor to install but the instructors are just say to install one end to the NEG and one end to the turn signal wire that has the relay for blinking. I have the black for ground and then a white/pink wire and a white/brown or orange wire.
The test light should be onboard at all times to troubleshoot your wiring. Good luck :-)
Check this thread...
https://www.jk-forum.com/forums/jk-w...ght-mod-20860/
Apparently it is the outside wire (furthest from ground) of unknown stripe color.
Well it's a 50/50 shot. And he said the one furthest from the ground wire. I would try that. Don't solder it in. Just use a couple of alligator clips to test it. That's what I would do anyway.
Front turn signal
My front right turn signal when I test the wires they both white and the white and tan both powerup but than the black ground also shows power what's up
Hello,
I would like your help guys to want to give a warning to the car behind me by flashing signal light right left but the response getting very slow to turn from right to left is that normal or because of resister hold flashcuation
